I have just replaced the impeller on my Buccaneer and have run it in a tank about three or four times but can't see where any water comes out.I took it apart again to make sure it was right and everything looked ok.The inlet tube is clear and I poked a wire up through the tube above the impeller until it hits a joint then it hits solid.If the tube is blocked above this point,do I have to take the motor apart at the power head to acess the upper portion of the water tube? Should the water come out the slits on the back of the housing or does it come out someplace else, such as a mist with the exaust? The motor gets a little hot but not extremly.The left side of the motor gets hotter than the right.I'm thinking about trying it on the lake because somewhere on this forum I read where running them in a barrel doesn't allow proper water intake. Any information would be greatly appreciated.Thanks!... I'm new to this forum and just realized I posted this in wrong catagory.Hope someone can help.
