Re: Mercury 60HP ignition coil not working?
Back to the shop. Swapped 3 different coils and none of them would show a spark using a timing light on the spark plug wire. But the timing light would trigger if clipped on the small wire running between the switch box and the coil. That is why it seemed the coil was bad.
Switched wiring up and down on the switch box and was able to move the problem around. Not good.
Finally went back to shop, got the new switch box again and put it on. Everything firing great now.
Seems my trigger was bad originally. Tried the switch box first, but of course it didn't fix the problem cause trigger was bad. Put old switch box back in then replaced trigger. Good trigger then but intermitant problem child switch box.
After a couple months of messing around, I'm still not fully convinced everything is perfect, but two days on the lake with no problems really felt good!
