  #1
Old August 14th, 2009, 10:04 AM
jon 61802 jon 61802 is offline
Default evinrude powerhead swap 85 to 115 or 135
I have an 1975 85 hp evinrude. I recently got my hands on what I was told to be a 115 evinrude from 1975 and was told it would bolt right up not have to change anything in the lower end. I was comparing diagrams on evinrude dot com and the 115 had a flat back in 75 and the 135 had a curved back and that is what this powerhead has on it. I talked to the person I got it from and was told that he pulled it from a running 115 hp evinrude. so here is my delima if it is a 135 would it fit on the 85 hp like a 115 or am I am pretty much going to have to replace everything.
  #2
Old August 14th, 2009, 05:45 PM
divinginn divinginn is offline
Default Re: evinrude powerhead swap 85 to 115 or 135
A friend of mine swapped a 140 block onto his 115 so I would think it would work. The 140 replaced the 135,I think his was late 70s model.
  #3
Old August 15th, 2009, 07:27 AM
emdsapmgr emdsapmgr is offline
All V4 crossflow blocks are interchangeable in a model year. They all use the same base gasket on the exhaust adapter. Two things to watch for on the early models: the configuration of the base gasket and the shift mechanism under the bottom carb. Base gaskets on engines 1977 and newer are different, when OMC went to the double thermostat housing. The powerhead changed again in 1978 when the shifter under the bottom carb changed. You will also find different mountings for the ignition 4 coils, depending on year. If you are swapping powerheads, make sure you get the correct carbs to go with it.
  #4
Old August 15th, 2009, 05:39 PM
ok this has no carbs can I take a 115 carb get the jets and install them into the 115 car and would that work or do I need to locate the 135 hp carbs for this
  #5
Old August 15th, 2009, 07:53 PM
ezeke ezeke is offline
If you have a set of 115 carburetors, you can use them on the 135 block as they are.
  #6
Old August 20th, 2009, 07:33 PM
MAW31 MAW31 is offline
would you not also need a prop with a different pitch?
  #7
Old August 21st, 2009, 07:37 AM
Crossflow carbs are made in different throat sizes-the size is cast into the front flange on the carb. The larger the carb throat, the more air/fuel that will go into the engine and the more hp it will make. The 85 carbs are small throat carbs (perhaps 1" throats), the 115's are larger (perhaps 1 3/16" throats) and the 135 carbs are the largest at 1 5/16" throat size. The engine will make hp depending on which carbs you use. If you want to make full hp on a 135 powerhead, get some 135 carbs.
  #8
Old August 22nd, 2009, 10:11 AM
Quote:
so you seying that I will tone down this motor and not give it as much hp if I went with a 115 carb. The guy I got it from said it was a 115. the pans on the back are consisten with a 135 so towning it down is more than fine with me I am affraid that it is to much for my boat and if that is all it take that is fine.
  #9
Old August 22nd, 2009, 10:46 AM
crb478 crb478 is offline
What is the model number on the round plug on the power head? That will tell you what the motor was/is. The 135 did have the bubble back exhaust, but someone may have added it to a 115. The 115 carbs will work and will likely only cost you on the top end. If you want more power you can look for a set of 135 carbs.
  #10
Old August 22nd, 2009, 10:53 AM
bailey bailey is offline
A quick suggestion, if the powerhead is complete (not bastardized),why don't you look for the numbers that are usually stamped on the quarter sized frost plug that you'll find on the top of you engine. Usually that number can be cross referenced thus enabling you to know exactly what engine you have.
Bailey
  #11
Old August 22nd, 2009, 07:25 PM
Quote:
Bailey
I tried that and they are not there. The guy that I got it from said he pulled it from a 115 but I started compairing and it has the bevel pan on it like the 135.
  #12
Old August 22nd, 2009, 09:22 PM
Dhadley Dhadley is offline
Location: Port Charlotte FL (almost -- its coming along)Never mind - it'll never be the same
If the base gasket is the same the powerheads will interchange. The carbs will all interchange and work as produced. It's very doubtful if you'll see any difference between the 115 and 135 carbs unless you're at or near 6000 rpm or more. The 85 carbs will work and will have a better holeshot and acceleration than the 115 carbs but may suffer just a tad on top. Again, it all depends on what your top rpm is.
  #13
Old August 22nd, 2009, 09:38 PM
well I have 115 carbs on the way. other than that it was pulled from a 75 115 acording from the guy at the marina and that it was a 115 powerhead
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
175 to 150 Evinrude Powerhead Swap pmrath Johnson & Evinrude Outboards 3 August 6th, 2009 11:26 PM
150 Hp Evinrude Powerhead Swap From 84 To 88 kgsmeatman Johnson & Evinrude Outboards 0 August 1st, 2009 03:29 PM
powerhead swap rpnlps Johnson & Evinrude Outboards 5 April 5th, 2009 06:46 PM
Johnson-Evinrude Powerhead Swap? Red Dogg Johnson & Evinrude Outboards 4 December 8th, 2005 07:04 PM
69 Evinrude 115 to 85 powerhead swap? scorpionryder Johnson & Evinrude Outboards 4 March 23rd, 2005 02:26 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
