  #1
Old August 14th, 2009, 06:15 AM
Barton3000 Barton3000 is offline
Red face Mariner 100 1988 bogging
Hi,
I´m new to this forum.
I´m from Sweden and i have searched all swedish forums for help on this problem, with no luck.
My Mariner 100 1988 (4-CYL) can run forever on idle and up to about 1800 RPM then it starts to bog down, as it cannot decide if it should run on 2 or 4 cylinders.
Rpm falls and it starts to shake very much.
Does anyone here know what controls the shift between running on 2 or 4 cylinders.
It has a new (red) stator with the black box. and a new CDI box.
How the heck does it know when to run on 4 cylinders or not?
Regards: Magnus - Sweden
  #2
Old August 14th, 2009, 11:13 AM
sschefer sschefer is offline
Default Re: Mariner 100 1988 bogging
Quote:
Originally Posted by Barton3000 View Post
Hi,
Oh Yeah, I got this one guys...... The way this engine is supposed to work is on a very fragile theory that the fuel mixture is not rich enough to burn but remains adequate to lubricate up to around 1800 rpms. At that point the throttle plates on the lower two carbs,which are tuned at the factory, are supposed to be open enough to provide enough fuel for combustion. However, the accelerator pump plays a big part in this in that it feeds two injectors on 3 and 4 that have check valves in them that can't open until fuel pressure is adequate. These two injectors are located in the block and are visible and accessible if you remove the electrical plate. There is also a hidden fuel filter between the accelerator pump output and the injectors. It is accessible if you remove the oil tank.
So, remove the oil tank and the electrical plate and then change the filter followed by removing the injectors, dissassembl them and clean and lube them with wd-40. Test them with a vacuum gauge to make sure the check valves are functioning correctly. Replace the injectors and the tubing that connects them to the "T" from the accelerator pump. The fuel line size is 7/64" and make sure you get fuel rated and not windshield washer hose.
Once you have all that done, rebuild your fuel pump and accelerator pump and you should be back in business. Just an FYI, doing only half the job will only result in frustration so do the whole job and you'll be back to great boating in no time.
  #3
Old August 14th, 2009, 04:22 PM
Great
Thats precisely the answer i was looking for, Thank you very much.
I will be on to it as soon as possible.
Thank you so much for your effort and time to write down such a detailed answer.
My best regards to you/ Magnus - Sweden.
Its a pity the boating season is almost over here in sweden.
  #4
Old August 14th, 2009, 08:34 PM
One last little tip. The fuel line that goes to the injectors loops back into the main fuel line before the fuel pump. This is wierd but there is a plug inside the tube immediately after the last fitting on the injector side. It needs to be there so if you think the lower tubing going under the lower carb to the main fuel line is plugged, you're right and it is supposed to be.
  #5
Old August 19th, 2009, 04:30 PM
Are you still here?
One more question about this.
If the injectors provide extra fuel for 3 and 4 while accelerating,
what gives fuel to 3 and 4 while the engine is on idle?
if the carburetor is completely shut and there is no idle circuit on the lower carbs.
Are they adjusted to let some fuel trough even if they are closed?
  #6
Old August 21st, 2009, 07:44 PM
Are you still here?
The carbs will spray adequate fuel for lubrication but not combustion. There is a factory set air mix screw on the upper left side of the carb. It has a red seal over it and is never supposed to be adjusted. The lower carbs do not have idle mixture screws either.
It's one weird setup if you ask me. My thoughts are that it is totally dependent on the quality of the available fuel and very precise timing.
I've recently dropped my initial timing to 20deg max at cranking speed (300 RPM) the previous tech note say's to set it at 22 and thats well down from the original that say's 27 or the sticker on the attenuator cover that say's 25.
Pretty much, once you have the injectors working properly the rest is voo-doo. Just keep playing with small timing changes and idle screw adjustments until you find the sweet spot.
  #7
Old August 25th, 2009, 02:40 PM
Thanks for your reply,
Yes it is one weird setup, I agree.
I have rebuild the fuelpump and replaced both fuelfilters and today i received the kit for the acceleratorpump
I ordered new injectors a few days ago as one of them was leaking constantly, thats why it took so much fuel.
Number 4 was completely soaked.
Hopefully I can give it a try this weekend.
Wish me luck.
About the sparkplugs they are NGK BPR7-HS10 are they not supposed to be 8 in heatrange?
I wish you the best/ Magnus-Sweden
  #8
Old August 25th, 2009, 03:26 PM
Wish me luck.
I run 8's in mine. I don't know what it called for originally but that's what they say to use now. NGK BPR8-N-10 gapped at .040 but please double check with NGK first, I don't want you to go on my word and burn a hole in a piston.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1988 4.3 merc bogging badly searaybob Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 5 May 21st, 2008 02:20 PM
1988 3.7 with bogging problems--HELP! ssbaw Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 3 August 9th, 2006 09:59 AM
1988 3.7 with bogging problem-- HELP! ssbaw Mercury & Mariner Outboards 0 August 8th, 2006 05:18 PM
1988 80 hp merc bogging down T. K. Mercury & Mariner Outboards 4 September 1st, 2005 06:19 PM
1988 mecury 135hp bogging out keswick Mercury & Mariner Outboards 4 March 21st, 2003 08:25 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
