jtcarter
- Apr 26, 2008
- 226
1995 evinrude intruder. I'm back to scratching my head over this one again. This spring this motor would top out at 5500-5700. Now i 'm lucky to reach 5000 rpm. It will run up to 5000 rpm then drop off to 4700, run back up to 5000 then repeat the process. I'd say thats a surge. #4 Plug looks kind of like its running lean. Not as tan as the other plugs and #6 Gets dirty or looks like it might be burning a little rich. Well i've took the carb off of #4 and went through all the jets with a thin peice of wire. I didn't find anything in there anyway. Checked float height. Its right at one inch drop to the bottom of the float which is within the speck. This motor has also killed two starting battery's in two years. Might just be coincidence. I did a rectifier test 12.6 not running and 13.25 at fast idle. Voltage guage reads 14 volts at higher speeds, is that normal? Seems like its charging the battery or at least the systems working. I do have another optical eye trigger i could try but i don't know. I know its not a fuel problem before the fuel pump,took the vent hose completely off inspected for anything in it, nothing. So that only leaves carbs, but i've been through them all a few times now. Carbs or spark but which one? All my ignition components are less than a year old. It is cdi stuff though. I never get accurate readings doing ohm tests on anything. So i might just have to take it on to the dealer.
