Hi ..... just joined today to help my Uncle (who's not Internet savvy) try to remedy a problem. His question is : Does the motor have to be completely removed from the transom in order to replace the two upper motor mounts ( or they may be described as dampeners ) between the transom mount and the actual motor frame ? What is the proper procedure to make the necessary repair ? He tells me it is a 1984 Mercury 50 HP 2 cycle 4 cylinder outboard, serial # 7209889.
I thank you on his behalf.
