i just purchased a 88 cobalt 22'6 bow rider with weight of 3800 lbs and would like to start shopping for trailer, have several ???
1) can i find a single axle? any advantage to double axle?
2)what do i need to look for that would be needed on my particular boat?
any tips and info appreciated. thanks
single axle NO
tandems is for you.
I have an EZ-Load trailer, dont care for it much.
bunk trailers are nice, easy to maintain.
look for one that is the proper lenght and weight for your boat. then adjust it to fit.
also it should have brakes, electric or surge is fine.
__________________
1983 22' Starcraft SC221 Bowrider 470 Mercury
1974 16' Starcraft American Bowrider 85 HP Johnson
Once you eliminate the impossible, What ever is left,
No matter how unlikely, Must be the problem.
How do I adjust to fit?
For example the boat is in the water now, if i purchase a trailer how do i haul the boat and have trailer set to go? Is it just trial and error or any specs to the whole thing?Thanks
Is there any reason that some trailer could just not be adjusted correctly? It is a deep vee boat.
Thanks
Dual Axle that way you don't lose your boat or get stranded if one of the bearings goes out like it did on me. I had to leave my boat on the side of the road overnight because of of the bearings went out. Fixed it the next morning.
Well I guess it ain't gonna be easy, thanks everyone
If you're buying from a dealer, ask him to take care of it. Might cost you a few bucks, but he'll have access to lifting equipment and yard guys to get you set up.
__________________
John and Linda
1999 Chris Craft 240 Express
5.7L Volvo-Penta w/Duo-Prop
2003 Dodge Ram 2500 Hemi
