90hp mercury 4-stroke.
This motor goes dead usually at WOT. It idles good. And seems to run good early in the day . It goes dead more often when weather warms. 85+ . Sometimes when it goes dead the primer bulb will be flat, but not everytime. I've changed the primer bulb twice, the hoses, the anti-syphon valve. I have also unhooked the motor from the boats gas tank, and hooked it up to a new tank. No change. My mechanic replaced a fuel pump. I think it's called the external fuel pump. No change.
My mechanic said there was another fuel pump . Could that be the bad one? Should I try another mechanic? Is there anything else I can do? Thanks
