We have 20 ft Kevla Cat with two 115 yamaha, today the strb engin resevoir pump shut down and the main tank run low on oil, the alarm shut down the motor, so no problem we refilled the oil tank on the motor and run the hole day releasing a 100lb sailfish
The main problem is that it shut down the port motor as well. Is this normal, why does both motors go into ideal if only one running low on oil??
Thanks
Thanks
