Re: pre-mix to oil injected
Like the other guys said, you're misunderstanding the change that is afoot - they'll be requiring 4 stroke or "DIRECT INJECTION" engines, which are different than "fuel injection" or "oil injection". They are the newest high tech 2 stroke, (EXPENSIVE) engines such as the Evinrude Etech or Mercury Optimax (and others).
As far as your question, you can make the change for about $500 or so:
Oil tank - $150-$200 retail, $50-100 used on ebay.
VRO/OMS fuel pump specific for your engine and alarms system: $450 retail, $300 discount online sellers.
Oil lines, connections, etc: maybe another $50
Pretty easy to do it yourself, maybe a couple hundred to have a shop install it.
