  #1
Old August 11th, 2009, 08:33 AM
Sharky79 Sharky79 is offline
Default Evinrude 35hp 1983 Not idling
I have an evinrude 35 hp 1983 which does not idle I've rebuild the carb with no improvment usually when i fire it in a tank it keeps steady but after i engage forward and put back to idle it will slowly die out, I also noted that when i turn the steering to one side it will increase rpms i don't know if this could be related any ideas ?
  #2
Old August 11th, 2009, 09:21 AM
alangf alangf is offline
Default Re: Evinrude 35hp 1983 Not idling
Quote:
Without more information this will be strictly a hip shot. One of the first things I would check is the idle speed. If it is set too low it will peter out and stall. The changing speed as the engine is turned sounds like a control cable problem. A good rule of thumb here (and most everywhere) is to always check the cheap things first. Good luck!
  #3
Old August 11th, 2009, 10:25 AM
countvlad's Avatar
countvlad countvlad is offline
does it run at WOT???
try to push the primer bulb when you get it started and see if that helps...
if it does and stays running while you prime and dies once you stop priming, you need a new fuel pump...
check the timing.... bad fuel.... carb adjustment
  #4
Old August 12th, 2009, 06:26 AM
I tried it at wot and it seems it lost about 2 knots on the gps I tried priming while idle and even at high speed but it doesn't improve. about the cable I've changed it but still does the same thing, i also tried to adjust the idle speed but it's not making much difference regarding revs
  #5
Old August 12th, 2009, 06:51 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
suggest link n sinc, then set idle in the water with it in forward. did you follow all the carb cleaning instructions >>>>http://forums.iboats.com/showthread.php?t=299680
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #6
Old August 12th, 2009, 08:41 AM
Are you sure you are adjusting idle speed and not low speed mixture? It's hard to imagine the idle speed adjustment not making a difference.
  #7
Old August 13th, 2009, 05:00 AM
I'm doing adjustments with the slow speed needle valve is there another setting i could try BTW I'm still an amateur regarding outboards so i use the selco manual but sometimes it`s not that straight forward any help is really appreciated
  #8
Old August 13th, 2009, 08:48 AM
I can't recall the exact setup on your engine since I have seen too many over the past 55 years that I have been boating. Idle speed is a mechanical adjustment that determines the degree to which the carburetor butterfly closes. Some have an adjustment screw and others require bending (manufacturers prefer to call it "forming") of the linkage itself. Pictures would be very helpful.
  #9
Old August 13th, 2009, 08:52 AM
you have only one adjustment, DO NOT bend anything!!!! you only have the slow speed needle, http://forums.iboats.com/showthread.php?t=167352
all other adjustments fall under linc n sinc directions.
if you do not have good compression, and spark, all the adjusting in the world will not help.
__________________
FLORIDA GATORS
TEBOW Country
  #10
Old August 13th, 2009, 09:31 AM
If i increase the throttle just a little bit it keeps stable and doesn't sound revving too much does this mean i still have to check compression and spark ? or shall I start directly by checking synchronization between ignition and carb ?
  #11
Old August 15th, 2009, 04:34 AM
I've tried to sychro the carb with the ignition following the instructions on the seloc manual but nothing is mentioned about the setting requried on the link between the throtle shaft and the carb any idea how to do this
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Stiff throttle 1983 35HP Evinrude Remote Rich W Johnson & Evinrude Outboards 1 October 21st, 2008 12:56 PM
1983 Evinrude 35hp Please Help RSTING Johnson & Evinrude Outboards 6 July 17th, 2008 10:01 PM
1983 - 35hp Evinrude / gearcase Captree Johnson & Evinrude Outboards 5 March 3rd, 2008 07:04 PM
which propeller for 1983 Evinrude 35hp Little.desperado Johnson & Evinrude Outboards 0 June 22nd, 2005 08:26 AM
81 Evinrude 35hp good idling, bogs out on throttle vmaxed Johnson & Evinrude Outboards 9 May 11th, 2002 03:15 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
