  #1
Old August 10th, 2009, 05:58 PM
avius avius is offline
Default Mercury 90 HP Carburetor Sync gauge
Need to sync my carbs now that I've taken them apart again.... But I'm not sure what kind of gauge I can use I could use some help.... Found this on ebay, but not sure that it'll fit my motors:
http://cgi.ebay.com/ebaymotors/Carburetor-Synchronizer-carb-sync-Gauge-CB-450-500-650_W0QQcmdZViewItemQQ_trksidZp4634Q2ec0Q2em14Q2el 1262QQhashZitem4cea65b67dQQitemZ330350048893QQptZM otorsQ5fAutomotiveQ5fTools
Anyone got any answers? Thanks...
  #2
Old August 11th, 2009, 04:33 AM
saumon saumon is offline
Default Re: Mercury 90 HP Carburetor Sync gauge
You don't need that at all.
In an OB, synchronizing the carbs simply means that they open at the same time. Loosen the link rod, so they'll be all closed, and retighten.
  #3
Old August 12th, 2009, 03:48 PM
Thanks saumon I'll do that. That seems perfectly logical now that I think about it. But I wonder why the Seloc book adds in the stuff about the motor needing to be under load and using a sync gauge and all that. Is syncing the carbs anything to do with "link & sync?"
  #4
Old August 12th, 2009, 04:22 PM
Quote:
Yes. Actually, it's the first step of the entire process. After that, you'll adjust the throttle and set the timing.
  #5
Old August 12th, 2009, 06:05 PM
hondon hondon is offline
Is this unit a 2 or 4 stroke?
  #6
Old August 12th, 2009, 07:51 PM
Quote:
Its a year 2000 4 stroke
  #7
Old August 20th, 2009, 05:22 PM
Would out of sync carbs cause the motor to die when WOT in gear?
Doesnt happen in neutral, but in gear under load it boggs then dies.
  #8
Old August 22nd, 2009, 09:12 PM
I'm not very familiar with 4-strokes engines but in 2-strokes engines, the first thing i'd look for this particular problem would be the fuel pump diaphragm. As yours is a carbed one, it should have a fuel pump too.
  #9
Old August 24th, 2009, 11:41 PM
Quote:
Thanks for the advice Sauman. When I took apart the carbs for cleaning I also took apart the fuel pumps (I have two per motor). Aside from a little varnish from the old fuel, they appeared to be okay. Naturally, I cleaned them up. The diaphragm itself was fine, had no tears or holes that I could see. I spoke with the Mercury outboard support guys and they told me that the only way to sync my carbs was to get a hold of a sync gauge set. This is the one I bought online : http://carbtune.com/. Haven't received it yet, but I'll be sure to post the results. HOPEFULLY this fixes my problem! I'll definitely post my findings though so that it may help the next guy that has similar problems.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
mercury 500 gear sync?! gristock86 Mercury & Mariner Outboards 3 August 18th, 2009 08:25 AM
Engine RPM's versus sync gauge? girlsdayoff Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 1 July 16th, 2007 04:54 PM
carburetor sync on 1984 175 Evinrude ralpht44 Johnson & Evinrude Outboards 3 August 15th, 2006 08:01 AM
115 Mercury shift sync. IB6UB9 Mercury & Mariner Outboards 6 May 14th, 2006 09:11 AM
Help needed with sync gauge Stratocaster Electrics, Electronics and Trolling Motors 11 February 3rd, 2005 04:51 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
