Hi guys new to this... I recently bought a 1985 115 hp mercury 6 cyl (6480195) 3 carbs (side bowl type wmk411a) of course it does not start.
It will turn over however (i know not good to do) I did spray some starter fluid into the carbs and it fired right up and then died.
I checked fuel lines and getting fuel to carbs and choke is ok (enricher valve).
I did take off and tear down carbs (carb #1 float was stuck) a spray down with carb cleaner jets ect... seemed good however tried to start...same problem (sprayed starter into carbs again, started and died)
Seems that gaskets on side bowls are no good. So i have ordered 3 carb kits and a fuel pump kit and will do a solid cleaning this time (lol from this site)
My question is since does fire up by using starter fluid and dies (Ill switch to mixed gas now for that test) Im assuming its not spark or compression... I just putting this out there in case missing anything... i will be doing a comp and spark test just to check out.... If you guys are out there thanks for any help.
