1986 Evinrude 90 HP
I've been trying to identify a rough idle and unspent fuel/oil problem. I did all the standard tests and got up to testing the VRO.
Ran clear hose on output side of VRO and pressure tested. At 800 RPMs the pressure would gradually drop from 7 to 3.5 PSI within 15 to 18 second cycles. Each time pressure reached about 3.5 PSI, I noticed a very small group of bubbles would pass out of the fuel outlet and just as they did the pressure would immediately jump back to 7 PSI. Then the cycle would repeat itself again.
Removed VRO and found it was not the original. It had part # 500455? ? can?t read last digit, but assume it was 8 or 9 (making it one of the newer OMS pumps). It has 4 wires and inlet and outlet fuel fittings held in place by a metal bracket and torx screws, and pulse limiter was blue.
I asked a retired marine mechanic I know to bench test it and will get back to him in about an hour. He said back in the day they did try to rebuild these but didn't have much success. He thinks I should replace with new. If the bench test points to a bad diaphragm, I'd like to know what folks on this forum would recommend- new or rebuild.
I'm not looking to premix, because since E10 I've decided to use up the gas in my tank at the end of each season in my truck. I do use stabilizer all year. I don't think its a good idea to let it sit 6 months.
Last question- in a correctly working pump, shouldn't the pressure stabilize and not behave like I described above? I figure as the air builds up in the pump it causes the pressure to gradually drop. Once that air bubble is released, the pressure returns to 7 PSI. As to my rough idle, I expect the air is causing it to mix too much oil, fouling my plugs, and leaving too much unspent fuel/oil in the exhaust.
