I'm hoping someone has had a similar issue with their OMC. If my J50 sits more than a couple of days it won?t start. Both cylinders loose spark, BUT if I continue to turn over the starter (off and on) for 5-10 minutes one cylinder will start to fire then in about a minute later both cylinders are firing. After that the engine will run perfect all day. I will do this same process every time I take the boat out. This last time I gave up after 10 minute without ever getting any spark. I have unplugged the ing-wires and jumped from the battery to the starter without any luck. Since the coil was cheap I replaced it first but it didn?t help. Something is telling me it?s the Stator but it could also be the Powerpack. These items are a little bit more money than the coil so if anyone can help it will be greatly appreciated.
Doug
PS, the oil injection has also been disconnected
Doug
