  #1
Old August 10th, 2009, 10:10 AM
cps22 cps22 is offline
Default Mercury 2005 115hp 4-stroke intermittent loss of electrical
I didn't see a similar post so am starting this new one.
2005 115hp Mercury 4-stroke
Purchased new in 2006 with 5-year extended warranty.
Intermittent Symptom occurred six times over the last two weeks:
Loss of most of electrical controls, instruments, starting, etc.
Symptoms eventually go away by themselves, only to appear again a few days later. Very intermittent. While boating on the Wolf River in Central WI, we cruised over 100 miles over the course of a 3-day weekend, about 10 hours of motor operation. The symptom appeared only on the third day while under operation.
Scenario 1: motor not running….. (occurred 5 times after motor was off for a day or two)
Motor won’t crank over
No power tilt/trim movement
No power tilt/trim display on dashboard indicator
No voltage displayed on dashboard volt meter, shows 0 volts
Accessories (radio, fish-finder,etc) work normally
Scenario 2: Motor running normally, boat cruising at 14mph
Gas gauge stops working
Tachometer stops working
Speedometer stops working
Observations & things tried…..
During scenario 1:
Voltage at battery terminals is 12 volts.
No tilt/trim, no motor cranking, etc
Took engine cover off, thought I heard “clicking” coming from engine, but not 100% sure, controls on this pontoon boat quite far from engine.
I swapped batteries between this and another boat, symptoms remained.
Purchased and installed a new battery, symptoms remained.
I have a wiring diagram and see a "main relay" shown but can't identify it on the engine itself. Also see that everything is wired into the ECM.
Anyone have any suggestions on where to look. This might be covered under warranty.
Thanks in advance,
CPS22
  #2
Old August 10th, 2009, 01:53 PM
corm's Avatar
corm corm is offline
Default Re: Mercury 2005 115hp 4-stroke intermittent loss of electrical
Hi,
Well I know nothing about a engine with ECM on it.
I would have thought a bad battery connection, but you
pretty much covered that. I'm guessing you cleaned the cable ends.
I think you may be headed in the right direction with the main relay.
I could not tell you where it is, sorry.
On another note the Wolf is FUN!
this is more of a "bump" post than help.
__________________
This is free internet advice.
Have Fun,
corm
  #3
Old August 10th, 2009, 09:12 PM
I did some more digging into the problem. Again, its intermittent and I can't duplicate it. However, I did find the main relay. I removed the relay to see if I could duplicate the problem, but even with the main relay removed I still had dash volt meter, gas gauge, tilt/trim. So confident now that its not the main relay.
I spent a couple of hours checking every connections within the motor, main harness, under dash, etc. Nothing loose.
I was able to create similar symptoms by removing the 20amp fuse on the motor for the "trim system & key switch". Symptoms were the same as the problem, no dash instruments, no tilt/trim, no cranking. The "hot" side of this particular fuse is connected to the hot side of the other three fuses as well as the output of the regulator. The "protected" side of this fuse supplies power to the trim switch mounted on the motor cowl and into the harness as a red wire.
Anyone have an idea or hint of where else to look for this intermittent problem?
Thanks in advance
CPS22
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
2005 115hp electrical Issue!!help!! snowy23 Mercury & Mariner Outboards 2 September 2nd, 2009 01:20 PM
2005 115Hp Mercury. James R Mercury & Mariner Outboards 3 October 14th, 2008 09:09 PM
2005 115hp Mercury 4 stroke tsmscscs Non-Repair Outboard Discussions 5 November 19th, 2007 11:11 PM
2005 115hp 4 stroke merc break-in? rob711 Mercury & Mariner Outboards 1 July 14th, 2007 06:51 AM
'94 25hp 2-stroke Yamaha with intermittent power loss fototrekr Yamaha & Suzuki Outboards 6 April 15th, 2004 05:33 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
