  #1
Old August 10th, 2009, 01:01 AM
ozzgood2001 ozzgood2001 is offline
Send a message via Yahoo to ozzgood2001
Default 1977 140 hp evinrude warm port side
after re firing this motor after 12 years of collecting dust it seems to be pumping good water although i have replaced the water pump but ran hasnt given me a chance to retest. but when first fired the port side is warmer than the starboard side. now i figured air bubble. but that usually happens starboard side.... i pulled the rubber hose on the rear of the engine port side and had moisture as water seemed to be coming thru.. could i pull that hose and start the engine see if any crud finds it way out? whats the easiest way to blow out the water passages in the block? i feel theres crud in there somewhere... all the plugs were wet so running lean doesnt seem to answer it. i can def. do 123 count on the starboard side without even takin my hand off. on the port side 1 2 OUCHIE LOL doesnt smell hot but i know at idle this shouldnt be. will the extra pressure from the new pump clear this up? any help greatly appreciated!
__________________
Chad G.
my 1976 starcaft SS 22' overhaul thread
http://forums.iboats.com/showthread.php?t=333352
got worms?
  #2
Old August 10th, 2009, 01:35 AM
66 joe 66 joe is offline
Default Re: 1977 140 hp evinrude warm port side
check thermostats?, had same issue w/ my 96 112, hot starboard and cool port side. after pulling off thermostats, found them both broken. replaced and now both sides are even 140-145
  #3
Old August 10th, 2009, 06:55 AM
emdsapmgr emdsapmgr is offline
There are two stats in the thermostat housing-each controls the temp for one side of the block. Likely the port stat is stuck shut. Also, when you have the stat housing apart, check the valve body. There are two very small pinholes in the middle which can clog up. Make sure they are both open, or it will overheat at idle when you reassemble it.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Evinrude 120 overheat on port side rickter111 Johnson & Evinrude Outboards 2 June 1st, 2009 01:02 PM
Still looking for the problem - port side warm other side cold lake11 Johnson & Evinrude Outboards 2 April 25th, 2007 12:52 PM
Low Water flow from Port Side of gimbal Housing and Port Exhaust Elbow hot. roorancher Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 January 30th, 2007 10:11 AM
88' EVINRUDE 110 NOT FIRING ON PORT SIDE Mmarycarroll Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 1 August 21st, 2004 09:15 AM
96 150 evinrude floods port side kadkins Johnson & Evinrude Outboards 4 May 31st, 2002 06:01 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
