  #1
Old August 10th, 2009, 12:16 AM
86bayyliner's Avatar
86bayyliner 86bayyliner is offline
Question 1990 150 evinrude. port side oil tank HOW DO I KNOW THE OIL IS GOING INTO THE ENGINE?
i dont want to blow up the motor and i dont know if the oil is mixing .. if i unplug the oil from the engine and pump the primer it comes out the hose... ???? ppl are telling me to disconnect it and pre mix the gas......
  #2
Old August 10th, 2009, 12:19 AM
billy4hp's Avatar
billy4hp billy4hp is offline
Default Re: 1990 150 evinrude. port side oil tank HOW DO I KNOW THE OIL IS GOING INTO THE ENG
Quote:
If your in doubt that it's pumping oil it is wise to premix the fuel (if the boat has a built in tank, pick up a 6 gallon external tank for this test).
Since it will now be running on premix for this test, the worst case scenario is you will be over oiling the engine. Now mark the oil tank and run the engine for a given period of time. If the oil pump it working, the oil level will drop...
I sure other's will chime in on how much it should drop but this should at least get you going...
Good luck...
__________________
1972 Glasply 16' Dungeness crab chaser
1978 Johnson 70HP
Solas Amita 4 - 12 3/4 x 17 (from iboats.com of course)
  #3
Old August 10th, 2009, 12:26 AM
Cool Re: 1990 150 evinrude. port side oil tank HOW DO I KNOW THE OIL IS GOING INTO THE ENG
thanks for the reply.. im going to try to do that tomarrow .. i just have to take my lower half off my engine and shoot some water into the hole the water pumps in so i can make sure its not clogged....
  #4
Zeeter Zeeter is offline
You should use about a pint for every six gallons you burn. Mark a line on the tank, youll see it drop.
Based on your other post youve got bigger problems. You are more likely to blow a cylinder from a gummed up carb. Bad oil injection does not blow just one cylinder, it wiipes all of them out.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Port side engine water cooling circulation lemor Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 6 June 2nd, 2008 12:19 AM
Engine Vibration / Port side manifold lrlima Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 10 May 18th, 2006 06:02 PM
88' EVINRUDE 110 NOT FIRING ON PORT SIDE Mmarycarroll Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 1 August 21st, 2004 09:15 AM
port side of engine is over heating on a 1988 225 v6 johnson fire tech Johnson & Evinrude Outboards 5 August 21st, 2003 08:58 AM
96 150 evinrude floods port side kadkins Johnson & Evinrude Outboards 4 May 31st, 2002 06:01 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
