Re: 11' + 6 Hp = Ok?
Thanks. I've got a couple other questions while I've got your attention...
First, what do you recommend I use for the hull numbers? The boat I'm getting is the Saturn 12', which is PVC. I remember on my last boat (also PVC) I ran into this problem before. I ended up using "magic markers" which eventually faded and had to be re-applied every so often. I also recall that some other people recommended using acrylic spray paint (with stencils and masked off). I plan on rolling the boat up between uses. What do you folks recommend?
And second, is there any particular place and method that you recommend I secure the fuel tank? I just picked up an el cheapo 6 gallon tank at WalMart, but I'm guessing it will want to bounce around in the chop. Any suggestions?
Incidentally, I also ordered the electric pump and a set of those wheels that mount on the transom. I should have everything by he end of next week.
