Well I'm new here and very impressed with the site so far. Anyways, I just bought a 73' Glastron Gt-150 with a 73' Mercury 650 65hp outboard on it and have a few problems I need to take care of. The motor and lower unit were rebuilt about 5 years ago (according to previous owner) and was bored out and ported and all and has about 80hp now. Anyways, it fires up everytime you touch the key and idles great but I believe the shifter/throttle cables need some adjusting.
Here is my problem:
Motor starts and idles great, when I rev it up with the motor in neutral with the little idle lever it will rev up great and feels like it will go full throttle. However when I push the shifter forward I feel it kick into neutral and the RPM's drop real low until I push it all the way forward, even when pushed all the way forward it feels like the motor is only at maybe 1/3 or 1/2 the RPM's that it does when in Neutral or that it should run. The motor runs fine then but it feels like I am just halfway throttling it.
I have looked and cant find a service manual online and am trying to figure out how to adjust the throttle cable and shifter linkage, does anyone have a link or a write up on how to do it? Any other ideas on what my problem could be?
Also, when I remove the housing there is no air filter. Should there be an air filter on my motor? I am new to boats but have been working on auto's for years, I got to thinking about it and thought maybe it didnt have a filter because you dont have dust and dirt on the water like you do on a road but still curious.
Thanks,
Spencer
Here is my problem:
Thanks,
Spencer
