Okej.
i removed the lower unit and put it in a stand on a tabel.
i removed the drain, refill plugs for the gear oil and it was plenty of water in it. about 2/3 water, 1/3 darkgray oil.
i belive i must skrew apart the gearcase and check the condition on the gears etc and to replce the seals, before i do that i want some inputs of how to do it right and if there is any major stuff to think of. the geracase cover i a solid part and looks a bit difficult to take it apart.
can i tell the gearcase i is good condition without take it apart? it spinns smoothly in both directions. must i take it apart the replace the seals or can i reach all seals from outside gearcase??
i also opened the pump house to check the impeller and it was very used
and it was some corrosion of the inside of the lid so that must be raplaced to but before i do that i must know the condition of the gearcase to se if its an option to repair it or not.
any of you know which literature to buy for my engine?
i have a repair manual for engines up to 40 hp but the lower unit dont look the same as mine so i cant use it as a good reference.
Any veterans out there that can give me some help, tip
