85volvosunbirdman
- Jul 15, 2009
- 39
Ok mine has three issues. First the guy I bought the boat from said water was in the lowwer unit oil last year. I am assuming that its the propellar shaft seal. Second, the first time I had the boat out it was going fine untill I rapidly went from 5000 rpm to idle but not nuetral. The boat slowwed untill wake pushed the back of the boat and it jumped into neutral. At the same time the boat shook front to back, I'm assuming from the neutral shift letting the prop spin free and not hold the boat going slow anymore. If I slow boat down slow this does not happen. Now third the boat is slipping out of forward and having lots of trouble getting it to go back into gear. Lots of neutral to forward tries and a little throttle seems to work. I had to drive boat quite alot like this to get home. I was four hours out and had to go through four locks. Thanks for your help in advance. Its a 1985 aq 125a with 270 volvo outdrive on a sunbird cuddie.
