vinyl flooring on ext plywood?
tony6813
will be installing marine grade vinyl on ext grade ply, I plan on sealing the plywood with poly resin first with no cloth. will the vinyl adhesive work with this "sealed plywood" ??
Bob_VT
Re: vinyl flooring on ext plywood?
Yes but the resin is not going to do you much good unless you add some cloth or at least a layer of csm. For that matter you can seal the wood up with epoxy paint and then glue the vinyl.
tony6813
what brand of epoxy paint? will I need to rough the service up before the adhesive.? I like the looks of Lunds boat flooring but cant find the brand that they use on there boats?? any ideas?
