shipwreck
- Nov 23, 2006
- 263
60 HP EVINRUDE 1967 SPORT FOUR
I can't run motor with fiberglass lid on it will not more than 7 miles , take off lid and it take 4 minutes but will get 25mph will go, but slow down it bogs has lack power get back up.
New impeller , t-stat (vernatherm) , new water passage gasket , and head gasket. The water passages have all been checked for restriction.
A tell tale has been add to # one cylinder which shows a steady stream which increase when them motor runs faster. It has been linked and sync.ed
I am run JC4 WITH .30 GAP
Question should i have water diverters in the block?
(see picture, it is a 70 v-4 from iwombats tell tale faq )
MY block dose not have any, this is way i bought used.
If so can someone tell where to install and what to use.
Anyone got ideas 90 psi and all four
new points condenser
new wires
new wires
