Re: Hydraulic tilt and trim problems?
Had the same motor and the same problem with the PTT.
There is a manual relief valve located at the base of the PTT cylinder. It is located on the starboard (right) side of the PTT cylinder right at the base. It is a plastic "screw" about 1/2" in diameter with a slot for a screwdriver.
If you unscrew the valve (CCW) about 2-3 turns, you can manually raise and lower the motor by hand. Turn it fully CW to engage the hydraulic system again. Problem I had with my unit was that the tip of the valve (plastic) had broken off inside the housing and allowed fluid to bypass the seals. I accidentally over tightened it and broke the tip off.
Easy and inexpensive fix if that's the problem. First thing to do as suggested is to check the fluid level.
