  #1
Old August 6th, 2009, 11:40 PM
JAL51974 JAL51974 is offline
Default Capri 1950 noise when turning ?
I posted on the Volvo forum about this low pitched vibration noise when turning either direction. This is on a AQ125a/270 drive. The ujoints were checked by a good mechanic last summer and were good. Anyone else have this problem or suggestions of how to start diagnosing it?
Joe
__________________
"SeaDog"
1985 Bayliner Capri 1950 BR
AQ125a/270
Even a bad day on the water is better than a day at work!
  #2
Old August 6th, 2009, 11:57 PM
lowkee's Avatar
lowkee lowkee is offline
Default Re: Capri 1950 noise when turning ?
I hate to question your mechanic, but what kind of 'good' mechanic says the ujoints aren't the problem, but you must figure out what is by yourself?
__________________
1990 Bayliner Capri 2050 BR - (My first runabout; Never seen her in water) ***Restore on hold until Jan 2010***
Restoration status: 0% --1--2--3--4@--5--6--7--8--9--10 100% Watch my progress here
1-Teardown 2-Transom 3-Stringers 4-Deck 5-Paint 6-Repower 7-Interior Frames 8-Seating 9-Water Trial 10-Upholstery
The 10 steps of restoration denial - Which step are you?
  #3
Old August 7th, 2009, 10:41 AM
The mechanics at that marina are Volvo certified mechanics and the place has a very good reputation. Last summer I had them change out the boots on that drive and give it an overall inspection. He told me that the ujoints were in good condition as i asked him specifically about that realizing the age of the boat and questionable service done by the previous owner. This noise only developed this season and I have only had time to use the boat maybe 5 times since the mechanic changed the boot. Otherwise it is stored on land.
If it is something I can diagnose and fix myself I will do that, but otherwise it means another trip to this mechanic who is 2 hrs drive from my town, so it is a major time investment just to get it to him. Nobody else locally will touch these old Volvo engines and drives around here!
Joe
__________________
"SeaDog"
AQ125a/270
  #4
Old September 21st, 2009, 02:37 PM
Default Re: Capri 1950 noise when turning ? UPDATE
Long story short-
mechanic examined the drive and found that while the ujoints are OK the crosses were shot so those were replaced.
However, while running it this weekend the noise is still present when turning! There is another bearing under the red housing that is between the engine and the transom the bell housing I believe. I am thinking now that is where this noise is coming from.
Anyone have any experience with this part?
Joe
__________________
"SeaDog"
AQ125a/270
  #5
Old October 21st, 2009, 04:42 PM
express 1 express 1 is offline
if the noise only happens when the drive is turned all the way over (either way) it usually is the gimbal bearing.nothing to do with u joints.should be grease fitting out side on transom plate.when drive is removed for winter gimbal should be seen. should also turn freely.
  #6
Old October 23rd, 2009, 12:50 PM
lowkee's Avatar
What ended up being the issue?
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1989 Capri 1950 gwershing Bayliner Boats 0 June 22nd, 2009 04:43 AM
2000 Capri 1950 thoughts Bilgamesh Boat Topics and Questions (not engine topics) 1 June 16th, 2009 11:44 PM
1982 1950 capri wiring diagram malice2003 Bayliner Boats 1 May 19th, 2009 09:00 PM
1988 bayliner capri 1950 blacknite30 Force & Chrysler Outboards 1 May 5th, 2009 12:22 AM
I need body parts for '89 Bayliner capri 1950 jamiewashere256 Boat Topics and Questions (not engine topics) 1 June 18th, 2003 03:26 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
