  #1
Old August 6th, 2009, 10:36 PM
JimStans JimStans is offline
Default Range and fuel capacity for a 1994 key west 1900 dc
I was hoping someone could give me an idea on what I can expect the mpg to be. I have a 1995 120hp evinrude. What is the top speed. Also the former owner thought it had a 40 gallon fuel tank but I thought it was closer to 60. I also have to get an anchor...any suggestions?
I can not find a manual so any info you have would be appreciated.
Thanks
Jim
  #2
Old August 7th, 2009, 12:08 PM
eli_lilly eli_lilly is offline
Default Re: Range and fuel capacity for a 1994 key west 1900 dc
For old 2 stroke outboards you can get a good idea of the MPG at full throttle by taking the HP rating and shifting the decimal place, ie 120 HP would get about 1.2mpg at full throttle.
I have the same boat and same year. I don't know what the tank capacity is, either, but I suspect 40.
-E
  #3
Old August 7th, 2009, 08:05 PM
Thanks! Assuming you are up on plane does the mileage go up as you throttle back?
The reason I asked about the tank capacity is that I thought it was 40 but the attendant wasn"t paying attention (I was also distracted by a bikini clad boater) and put in 45 gallons. I was worried that there might be a leak or something but I couldn't find anything. Then when I was online I looked up the specs on a new 1900 and it has a 60 gal. tank. So I am hoping it is 60.
Thanks again. If I find out I will post it.
  #4
Old August 11th, 2009, 12:25 PM
Quote:
Yes. I usually run around 3K rpms. That's about 25 mph on my rig and about the slowest I can go and still plane. I'd guess I get about 2-3 mpg at that speed. It's hard for me to get straight range numbers because I'm always running a combination of planing and idling, due to the slow speed zones down here in South Florida. I'd probably consider 100 miles to be a good range number.
Yeah, it does feel like it holds more than 40 but doesn't seem like 60. I wonder if its a 50 (even though there is no mention of such a size on the KW web site).
-E
  #5
Old August 14th, 2009, 10:17 PM
Sorry it took so long to reply. Thanks for your help. I have been doing some research but have not been able to confirm the tank size. I will keep looking.
  #6
Old August 18th, 2009, 10:15 PM
Boatdood Boatdood is offline
Click the link here http://keywestboatsinc.com/faq/page/4 to go to the FAQ section on the Key West Boats web site regarding fuel tank sizes. The 1900 has always had a 60 gallon tank. Mileage figures vary greatly but the tank size is always the same.
  #7
Old August 19th, 2009, 05:27 PM
Quote:
I saw that too but I'd say there is no way my 1900DC has a 60 gallon tank. Although it probably really does and the fuel sender is just set to look empty at 1/3rd tank.
-E
  #8
Old August 19th, 2009, 10:27 PM
If you've got one of those old swing arm floats on your sender it can be adjusted fairly easy. Pull it out and bend the arm as needed. I was selling those boats new at a dealership in '94. Trust me, they hold 60 gallons when they are empty.I always thought that was a big tank for that boat but outboards were thirsty in those days and some folks thought that boat was enough to go way offshore. I never heard of any of them not making it back though.
  #9
Old August 20th, 2009, 02:06 PM
OK, thanks, BD!
-E
  #10
Old August 20th, 2009, 09:55 PM
mhg mhg is offline
My 1900 CC has a 60 gal tank. I pulled the label off the tank while I had
the console off for tank cleaning.
I can not remember where I saw it but mine was listed as having a 50 gal
tank in a set of specs.
Also mine will show empty when I have 20 gal. still in it
M.
__________________
MHG
19' key west CC
140evinrude
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Fuel capacity range 1960vw Boat Topics and Questions (not engine topics) 3 May 31st, 2009 01:37 PM
Key West 1900 w/DT150 going from 20 to 17 eli_lilly Prop Questions and Topics 2 April 7th, 2009 10:49 AM
1900 Key West Sportsman question Swain911 Key West Boats 3 February 25th, 2009 02:57 PM
Restoring the Hull of a '94 Key West 1900 CC Grits Boat Restoration and Building 6 February 20th, 2008 11:14 AM
restoring the Hull of a '94 Key West 1900 CC Grits Boat Topics and Questions (not engine topics) 0 February 18th, 2008 04:59 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
