I hope you guys can help me with this problem.
The motor start easily. Out of the water I have no problem. When I go in the water it maintains good idle speed in forward and reverse. Then when I start acceleration it turns off. Looks like an air-gas strangled.
It starts again like nothing happened. Then I startr acceleration again pressing the choke and it runs perfectly well. The choke is only needed to pass 2500 rpm. Then it runs smooth and steady.
Thanks for the help.
