I just bought a new boat, took it out with the seller and it seemed to run fine and after having a mechanic look at it, I was towing it home and the center console fell over when i was towing it back home. The console was a piece of crap that the guy built. After building a new console, i took the boat out and it would only barely get into drive and wouldn't go into reverse at all. I noticed that the neutral arm lock on the control box (plastic piece that you press to get it into and out of gear) was broken, so I replaced that. Tried it out tonight and it still would only barely get passed ideling speed and the reverse worked a little bit. The engine would also cut out a few times after trying to give it gas. Started to smoke a little too.
Anybody have any ideas what this might be from. Just weird because it worked fine when i took it out with the seller. The only thing that happened was the console falling over, but that didn't touch the outboard at all.
