bang4dabuck
- May 24, 2009
- 296
I have replaced therms and still have heat problem on starboard side. I have not changed impeller/water pump yet but was going to do it anyways as a precautionary measure. I feel I still will have a problem since port side is nice and cool as other side gets hot. In other words the impeller is not the problem. Am I presuming too much ?
My thought is to get to the water jackets and replace the DEFLECTORS.Are they usually the CULPRITS ??? Why do they list the CHECK VALVE ASSEMBLY under the same number ( 10 I think)? What is it ? In some other post somebody mentioned PRESSURE RELIEF VALVES for similar issue. What are they ?
