  #1
Old August 5th, 2009, 11:42 PM
palofmine palofmine is offline
Default Bilge Pump Issues with Super Hawk
My boat is a 2008 18' SuperHawk 4.3L I/O. Runs great and very happy with it overall, with the exception of the bilge pump.
First issue is that the bilge pump no longer kicks in automatically, requiring me to start it manually even when water level in the stern gets close to the top of the pump. To try and resolve I unscrewed the pump, shook it, but did not hear any rattle to indicate the float had become unstuck if indeed it is stuck and I should hear it if not stuck. Is there any further action I can take to get this automatic mode working? The pump works fine in manual mode with the exception of the next problem.
Vapor lock is a persistent problem with this pump. More times than not I need to slide the hose off the pump while the pump is running, but no water is flowing, in order to get the water flowing through the hose and out.
Is vapor lock caused by the pump itself, or just an intermitten problem caused when the pump tried to run and it takes in only air?
Any suggestions on how to correct would be most appreciated.
  #2
Old August 7th, 2009, 04:30 PM
rndn rndn is offline
Default Re: Bilge Pump Issues with Super Hawk
First off, Welcome to the iboats.com forum!!
It really sounds like you should replace the entire unit. You may also want to note that the float may be a seperate piece, just something to look out for. Bilge pumps are just one of the very important things that you don't want to try to get by. As long as the float is getting electricity then it's time to replace it, if it's not getting electricity, then it may be your dash switch.
__________________
1996 Crestliner 2160 Phantom, 1996 Evinrude 130 HP
  #3
Old August 8th, 2009, 12:11 AM
Thanks for the welcome RNDN.
On float issue, totally agree on the need to be more diligent on the float, pumps and everything not winterized by my mechanic, esp given the boat is stored in an unheated shed over the winter in Minnesota.
The original float is a Johnson Mayfair 3617. It is still under warranty so I will get another as a backup. If the dealership agrees exchange for credit for the Mayfair Ultima switch, since the Ultima is totally electronic, watertight, and as long as the "eyes" on it are kept clean should be more reliable and work better over time.
The issue with the pump running but no water being pumped seems to be an issue related to the output hose dipping down lower than the pump before rising to exit out the upper port side creating an air gap. Will get the hose changed to remove the dip and see if that fixes this issue.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Super Hawk Front Pedestal too low crobar Crestliner Boats 7 June 21st, 2009 10:30 AM
Bilge pump and trim motor issues. TheMFA Electrics, Electronics and Trolling Motors 3 January 26th, 2009 04:18 PM
2008 Crestliner Super Hawk I/0 Good price or not ??? RCKYMTAIR Crestliner Boats 4 June 11th, 2008 01:35 AM
2008 Crestliner Super Hawk I/O 3.0 ?? RCKYMTAIR Crestliner Boats 11 February 28th, 2008 03:23 PM
Sylvan Super Snapper 2002 Bilge Pump speedbird1 Sylvan Boats 0 December 22nd, 2007 03:14 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
