The boat we are talking about is a '98 Regal 1700 LSR. This boat has been out of the water for about 8 years now(it was used 3 times before I got it). When I launched it just recently, I found a lot of water would accumulate in the hull of the boat. After wrapping Teflon tape around the drain plug to make sure it wasn't coming from that, I let it sit docked for 45 minutes, after which no water was in the hull. Once underway again, I found more water. I eventually found that a tube which is coming from the outdrive, will have no water coming from it while docked, but will have a lot of water coming from it while driving. I have no idea where this tube goes, but after reading a bit it sounds like water coming from the outdrive used for cooling? I ran the tube outside of the boat while underway and it cut down on the water coming in but did not eliminate it.
My question is, where does this tube go and what is the best solution for stopping the leak? Any help is appreciated!!
