Re: Test driving used boat.
As you say tractoman, run the boat through its paces, check how it starts hot and cold, does it plane easily and run easily at cruise, and full speed/high rpm. Make sure you have a enough gas for at least an hour on the water. Try the tilt and trim, go into some hard turns etc.
For a sea trial load the boat the way for its intended use. If you plan to carry 4 or 5 people make sure you test the boat that way.
A lot of boats perform well with a light load, but test the boat the way you plan on using it.
Check the gauges and lights, test the bilge pump, look for water in the bilge
before and after the test. Have a look at the oil in the outdrive.
Good luck
__________________
Stanley Islander 19, Yamaha F150
