Re: HELP!!! Pontoon Steering Locked up.
Pontoon boat steering is no different than any other boat. I am assuming it is Teleflex. Start by breaking down the problem. Disconnect at the motor. Is it the motor? If the motor turns freely manually, move on to the steering wheel and to the part under inside the helm. Disconnect the cable there. By breaking down the problem, you will find the cause and solution. Get back to us after this exercise. ALMOST every component can be fixed.
__________________
I've fished for half of my life, the rest I just wasted.
