  #1
Old August 5th, 2009, 10:53 AM
CaptainKev CaptainKev is offline
Default Re:Trim Gauge & Sensor.
I have a 2400 with Volvo 5.7 GI and a Duo-prop stern drive. I would like to have the trim gauge working without having to turn the ignition to start/run. In other words........I want the gauge to work any time the drive can be moved. I'm not sure if this is a common issue, or just Regal, but I'm very uncomfortable knowing that the drive can be moved without any indication of the position. I've gone through my owners manuals for both the boat and the stern drive, but neither show the circuits that would be involved. Obviously, the trim gauge power is supplied through the gauge cluster harness, but what I don't know is does the trim sender on the drive get the power from the gauge, or someplace else. I'm not concerned with battery drain because the only time the battery switch gets turned on is when I do shore checks, or right before I launch. Any help, or information would be appreciated.
Kev.
  #2
Old August 9th, 2009, 08:05 AM
Mischief Managed Mischief Managed is offline
Default Re: Trim Gauge & Sensor.
The trim sender is simply a variable resistor (rheostat or potentiometer) in a loop like this: plus 12V---ignition switch---sender---gauge----negative 12V. The function of the sender is to vary the voltage to the gauge.
You might be able to rig a switch to feed plus 12V between the igntion switch and the sender, but it will "backfeed" voltage to anything connected to the same circuit. A diode in-line would prevent that. Rather than the switch, I think I'd use two diodes and make the outputs of the trim up an and trim down solenoids the sources of the +12 volts so that with the ignition off, the gauge is only working when the drive is moving.
  #3
Old August 14th, 2009, 04:45 PM
Great suggestions Mischief Managed. My gauge package is supplied +12VDC from the ignition, starting at the trim gauge and then piggybacking to the other gauges from there. There are four terminals on the gauge. Two of them are +/- 12VDC. The sensor output is connected to the third terminal. The fourth terminal is a mystery, at the moment. It's a male spade connector with a wire with an insulated female connector going to it. In retrospect, it may be a lighting supply. I spent quite a bit of time trying to locate the sensor cable last evening and didn't have any luck. The sensor is located on the starboard side of the drive and the cable goes through the transom T.D.C of the drive. I know the cable has to be coming out right behind the engine, but I couldn't find it before I got bitten up so bad from our friendly mosquitoes. I'll grab a can of "Off" and try again tonight.Since I can easily isolate the gauge from the rest of the package, I'm going to give your first suggestion of an in-line diode a shot...........if I can find the durn thing. Thanks for your help.
Kev.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
is the temp sensor for the gauge the same as in a car?? lime4x4 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 June 21st, 2009 10:18 PM
Trim sensor reads backwards (new sensor) Isoprime Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 8 June 19th, 2009 12:05 AM
Volvo DP-SM trim sensor / gauge issue dn549 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 0 August 11th, 2008 02:36 PM
Any Tricks...Trim Gauge Sensor Wires? budhirst Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 June 19th, 2007 05:49 PM
Location of trim gauge sensor, 90 Evinrude? videofxr Johnson & Evinrude Outboards 1 June 10th, 2002 07:25 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
