FICHT interchangeable parts
TrukKW
Hello all,
I recently found a great deal (hopefully) on a 2001 FICHT 200 with less than 500 hours. I need to find a few parts for it now. I specifically need a throttle body and starter solenoid. I've been looking around on the internet and have found used throttle bodies from similar engines. Either the parts are from a 200 1999 or a 175 2001. Are these parts interchangeable between years/or HP?
wilde1j
Re: FICHT interchangeable parts
Your engine (as I'm sure you know) is DI. Most induction parts from other OMC/BRP carbed motors probably will not work. If the motors you're looking at are also Ficht, then good chance they are OK. Throttle body is likely HP dependent, starter solenoid is likely OK. You can get a better idea from examining the parts diagrams on BRP's website. If the PN's the same, then OK.
