I had an older 14ft boat that has a 40 hp. Johnson seahorse, I bought a newer boat with a 50 hp Johnson and the old one sat for a couple years then I gave it to my two boys and that is when the problem started. Last time I used (1963) it, it ran like it was new, The first time the boys tried to use it it would bog down under load. In neutral it ran fine but as soon as kicked it into gear it would bog down with no power or rev's. Checked plugs, carb is spotless, jets are clear. Thought it was a fuel problem but find nothing wrong. Talked to a couple people that tell me it is an electrical problem, not getting enough spark. Starts easy, runs good in barrel, runs fine in the lake in neutral, no-go when put a load on it, is the best I can discribe what going on. HELP need to get my boys fishing!!!
