  #1
Old August 5th, 2009, 12:37 AM
jjbarnes jjbarnes is offline
Question 70's Model 40HP Mercury Stator Compatability
I recently was given a 73 mercury 402 40hp outboard to replace the blown Johnson that came with the boat I just bought. Lucky me huh. Well the wiring has turned to dust and I am wondering what is the best place to find a stator and wiring harness? I need the motor side of the big plugin. My REAL question is how many models have those same parts. It looks like about any mercury from that era has the same style plug. What about the stator on a model like that? If anyone knows how big of a net I can cast for my search I would greatly appreciate it.
BTW- I have popped into this forum to search questions in the past and I have to say, as a casual reader, there are some of the most helpful people on here. I belong to woodworking and other forums where everybody just brags about their stuff and offers little real help. There must be something in the water.
Thanks in advance.
  #2
Old August 5th, 2009, 09:19 AM
mmf mmf is offline
Default Re: 73 Mercury 402 40HP
I have repaired the wiring on alot of these 70's models, all now suffer from the dreaded wire rot, thanks to mercury using rubber covered wires instead of PVC insulation. Fixing the problem if you want to go back with NEW parts is expensive. You can get a new male engine plug from CDI Electronics online (www.cdielectronics.com) but the plug is almost $200! They also sell replacement stator coils, also about $200! I have saved some stator coils by being very careful with bending the wires especially where they enter the coil stator, first I cut the wires close to the stator coil leaving enough for a butt splice connector then I check resistance per CDI's troubleshooting charts, if OK, I crimp on uninsulated butt splices on to the cut wires then slide on short pieces of heat shrink, the thick type with the glue inside of it, then I shrink the tubing down. After this, I squirt a modest amount of urethane PL flashing adhesive (http://www.stickwithpl.com/Products....ashing-Sealant ) to the area around the stator where the wires enter it and some on the short pieces of wire with the butt splices. I smooth this out and let it dry completely (24 Hrs.), this stuff dries tuff and makes an excellent "strain relief" to this area, then I crimp on my new PVC insulated wire, I use MTW type wire which is (machine tool wire, and oil resistant), it is limp and easy to harness and you can get from your local electrical supply house. Just doing this saves me $200! I also do this to many switchbox's that have wire leads coming from them and the male plugs that attach to the lower cowling.
  #3
Old August 5th, 2009, 09:45 AM
Unfortunately the stator wires have already sheared off right as they come through the grommet. There is NOTHING left to attach too. I can get by without the plug if I have too since I could just direct wire everything through the cowling. I found a stator off a '70 40hp mercury that is in useable shape and I am wondering if it will work or what models/year range I can look though. Thanks.
  #4
Old August 5th, 2009, 09:56 AM
daveswaves's Avatar
daveswaves daveswaves is offline
Quote:
Since your stator is kaput any way, you can dig out the rubber grommet and expose another 1/2 inch of wire, which, if it is in good shape you can solder new leads to. Heat shrink the joints and re pot in silicone rtv, black.
__________________
Mercury inlines....nothing else stacks up
The answer to "do i need to change my water pump impeller" is YES
  #5
Old August 5th, 2009, 10:04 AM
I wasn't sure if taking the grommet out was possible. I tried pulling on it a little but with no results. And by tore off at the grommet I mean the wires are already about half way down inside it. I was going to take one more crack at it this evening by carefully grinding away the little retainer around the grommet and see what I could get but I don't hold much hope.
  #6
Old August 6th, 2009, 11:13 AM
westexasrepublic westexasrepublic is offline
Default Re: 70's Model Mercury Stator Compatability
I went here >>>>>>>>>>> http://www.marineengine.com/ <<<<<<<<for all my electrical replacement parts and saved me over $200 dollars! everywhere else had significantly higher prices.
for the same reason as you, I replaced my Stator, Trigger, rectifier, water impeller kit, miscellaneous gaskets, and a fuel line fitting for $375 w/ shipping!
if I couldnt find it I used Crowleymarine.com for part numbers and search marineengine.com And found everything.
The only thing I found that I was able to really save money DIYing was my wiring harness. Heres pic of how I cut it up and soldered new wires...
  #7
Old August 6th, 2009, 12:00 PM
Default Re: 70's Model 40HP Mercury Stator Compatability
Nice work on the harness, very clean and professional looking once it was done. After looking at mine more closely last night I think if I cut back part of the plug I can get about 1-1.5" of good wire and make splices off that. I should be able to tackle that and if not I'll run the wires about a foot outside the motor and throw away the original plug entirely and make my own. Lest ye forget what a true hillbilly would do, I R 1
The stator is still up in the air though. marineengine.com has it listed pretty high at over $200. iboats has an aftermarket for about $195. I saw a list of resistance and voltages for merc stators and looked at the '70-71 models vs. the '72-81 and they look virtually identical. The numbers are a little different but they use some common parts like the rectifier and I think the trigger. Does anyone know if the 174-4424 stator ('70-71 model) can actually replace the 174-5255 ('72-81 model)? I have a line on one fairly cheap but don't want to throw money away on something that won't work. The guys on the internet who has it doesn't know for sure either.
  #8
Old August 27th, 2009, 10:27 PM
supreme supreme is offline
jjbarnes, I found this site for parts, http://www.boats.net/ good prices.
Devin
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
mercury 40hp allymoss Mercury & Mariner Outboards 2 August 7th, 2008 10:10 AM
80-81 Mercury 40hp No Pee NSG14RYDA Mercury & Mariner Outboards 10 March 22nd, 2008 10:41 PM
Mercury 40hp Salmosalar Mercury & Mariner Outboards 3 October 17th, 2007 11:59 AM
40hp mercury ptl Mercury & Mariner Outboards 7 June 28th, 2004 08:19 AM
40hp mercury ptl Non-Repair Outboard Discussions 1 June 21st, 2004 09:15 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
