I recently purchased a 1976 boat with a Volvo Penta AQ130C engine and 280 outdrive. Runs quite well until I'm getting up toward 2000 RPM, then it will stall as if it's starved for fuel. It will sometimes recover before completely stalling, or it may stall and not restart for a few minutes. The previous owner mentioned that he believes there is no thermostat installed, and the temperature gauge would seem to indicate that is the case (or it is stuck open) as the temp when operating barely gets out of the white range into the green. When it stalls, the temp goes half-way up the gauge. Could this stalling be carb ice? If so, in both carbs at the same time? It did this again yesterday, then would not restart for about 5 minutes. Then it ran until we got near the dock, when it stalled as I dropped to idle waiting for a spot at the dock. Any thoughts or ideas? Thanks, Bob
