10 HP Merc not gettting gas to cylinders
boater rick
I drained the carb of some water, put new plugs in, confirmed I got spark but plugs are dry. If I pour a little gas in cylinder it will attempt to start. Bulb now goes hard as well.
Any ideas what to check next?
rosser1
Re: 10 HP Merc not gettting gas to cylinders
if carbs have water more than likely tank may have water also. check and see, let us know. a little fuel in cylinder not a bad idea but to much and you lose compression
green4themoney
did you actually take the carb off and clean it thoroughly? and re-adjust your low speed jet?
boater rick
Yes, I since did clean the carb, and now it won't start without choke pulled and fast idle pulled. Once running I can push in choke, and slow down idle, but still running a little fast. Should the air screw be turned 1 1/4 turns back from all way in? Any other asdjustments I missed?
boater rick
where by the way is the low speed jet? I only see one slot screw on right directed toward center of carb?
James R
Saying you have a 10 hp merc is like saying "I have a car". What model and year do you have.
