  #1
Old August 4th, 2009, 04:57 PM
rooooney rooooney is offline
Default can a 9.9 push a 24 foot pontoon?
I am looking for a pontoon boat but my lake has a 9.9 limit- I found a 24 foot without a motor that i considered buying but will a 9.9 move it or do I need to find a smaller boat? Thanks
  #2
Old August 4th, 2009, 07:48 PM
5150abf's Avatar
5150abf 5150abf is offline
Default Re: can a 9.9 push a 24 foot pontoon?
Technically yes it will but obviously not fast, a 55lb trolling motor will move a toon that size and a 9.9 has alot more power than that.
You should be fine with that set up.
__________________
GO IRISH!!!!
  #3
Old August 4th, 2009, 08:38 PM
Bigtimber Bigtimber is offline
Slowly but surely. No speed demon of course and it could get alittle aggrivating at times...but ya I would think it would bump around alright. Went to the Okefenokee swamp park awhile back...they had some, I'd estimate, 20 foot carolina skiffs loaded down with maybe 15-18 folks and they pushed them all with those 9.9 mercurys. Nothing fast but bumping right along pretty good.
  #4
Old August 4th, 2009, 09:37 PM
rolmops's Avatar
rolmops rolmops is offline
My 9.5 kicker pushes my very deep V 19 footer with a full 20 gallon tank and a 75 horse mercury with lower unit in the water at about 5.6 mile (gps) per hour.You should get a little better than that.
__________________
Make sure the plug is in
  #5
Old August 5th, 2009, 02:01 AM
samo_ott's Avatar
samo_ott samo_ott is offline
When I first got my 16' pontoon (8' beam) it came with a 1961 Evinrude 5.5hp. I thought it would blow sideways down the river but it held it's own. Even with 4 or 5 adults in it.
So a 9.9 should move a 24'er similar I would think. Or you could do like a lot of others talk about and put a 15hp cowling on a 9.9. Oops... did I put that in writing!
__________________
Steve.
  #6
Old August 9th, 2009, 07:59 AM
Jeff-in-PA Jeff-in-PA is offline
That's what I have on my 24' pontoon. I forget the exact mph, put it moves fast enough to get around ( or back as that's why I checked it out before I had to ). You will not be setting any speed records so I hope you enjoy the ride.
I think that should read a 15 hp outboard with a 9.9 cowling
  #7
Old August 9th, 2009, 11:11 PM
junior1113's Avatar
junior1113 junior1113 is offline
need a very low prop pitch for best outcome like 6-7" pitch
  #8
Old August 9th, 2009, 11:14 PM
fishfindin fishfindin is offline
Quote:
you could, but it would be slow movin from there.
  #9
Old August 9th, 2009, 11:39 PM
rs2k's Avatar
rs2k rs2k is offline
Quote:
I once saw a big bass boat with a BIG engine that had an 8 HP label in a lake with a limit.
__________________
Better run away!
I gotta twin engine stringer powered cabin cruiser!
1980 28' Imp Kansa w/2x OMC 260HP 350 Stringers.
  #10
Old August 10th, 2009, 12:47 AM
nimmor nimmor is offline
There is a small 60 acre lake I fish sometimes that several of the local residents have 9.9's on there pontoons all sizes. This is also a 10hp max lake but it is also a no wake lake so speed is not a factor. So the 9.9 will work fine. The first time I ever fished this lake I am talking about it really shocked me to see nice $200,000-$300,000 homes with nice big pontoons parked at ther docks with a little ol 9.9 mounted on them. The nice thing about these lakes is you don't have the pressure of the big wave boats and jet skis, just a great place to fish.
  #11
Old August 10th, 2009, 01:51 AM
xxturbowesxx xxturbowesxx is offline
I would find the largest motor that a 9.9hp cowl can fit on. I know this may seem wrong but its not like your pushing a 10'john boat so speed wont be an issue and I doubt anyone will take a second look.
  #12
Old September 10th, 2009, 11:02 PM
kciv kciv is offline
I bought a 24' pontoon boat and needed to move it across a lake. I put my 14' jon boat on the pontoon boat and used its 5 hp to push it. Oddly enough the pontoon boat with the jon boat moved just about as fast as the jon boat with the 5 hp.
  #13
Old September 10th, 2009, 11:28 PM
kenmyfam's Avatar
kenmyfam kenmyfam is offline
You will move but no need to take the water ski's
__________________
1985 Doral 164 1985 140hp Johnson EZ loader single axle trailer all = a whole lot of family fun !!!!
Windsor Spitfires. Memorial Cup Champions 2009
  #14
Old September 10th, 2009, 11:29 PM
rs2k's Avatar
On small planning hulls hp doesn't seem to matter much until you try to get out of the hole (Assuming motor thrust is greater than wind resistance). Look up the term "hull speed" or "displacement speed".
I can pull my 28' boat pretty about as fast as I jog with a long enough rope. I put out much less than 9 HP.
__________________
Better run away!
  #15
Old September 11th, 2009, 12:50 AM
Lion hunter's Avatar
Lion hunter Lion hunter is offline
Master Chief Petty Officer
At only 60 acres a 9.9 will get you by fine. Thats only a little over a 1/4 mile wide so skiing probably ain't happening any way. At 5 mph you'll cross it in about 3 minutes. And you'll run forever on a 6 gal tank and be able to enjoy fishing with no wakes. Sounds fun to me.
__________________
The Crestliner Restoration
http://forums.iboats.com/showthread....49#post2218249
1967 16' Crestliner and 60hp Johnny
Klamath Trailorboat and 9.9 Johnny
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
16 foot pontoon boat rqbayliner Pontoons 4 July 31st, 2009 08:56 AM
Suzuki DF40 - 18 Foot Pontoon Silvertip Non-Repair Outboard Discussions 1 June 22nd, 2008 10:09 AM
24 foot pontoon trailer lyndze Trailers and Towing 3 August 23rd, 2005 10:50 AM
20 foot pontoon FSHKPR Boat Restoration and Building 3 August 18th, 2003 03:03 AM
14 foot Pontoon boat Moose52 Mercury & Mariner Outboards 3 July 28th, 2001 11:25 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
