I have a 1970 Evinrude 85HP V4... bought it used, powerhead and everything runs great. I first started to notice it was overheating so I took off the lower unit and found that the nylon water pump housing had MELTED, and the impeller obviously was in horrid shape as well.
Anyways, at the same time I had checked the gear lube and been changing it. It has been coming out pure white, so I figure I had a leak somewhere. After I replaced the water pump I took it out, ran great didn't overheat, but my gear lube was still white when I went to drain it.
Checked the plugs and noticed the lower drain plug didn't have a seal on it, duh. Well I replaced the seals and took it out again. Gear lube is still white, to make matters more interesting it's leaking this milky lube out of the weep hole on the portside of the motor on the lower unit. I believe this is an outlet for water from the pump as it pisses a little when on muffs.
Either way, when I was in the motor I pulled the upper bearing housing below the pump and replaced the seal on it. I also replaced all the seals on the pump itself and the shaft seal/rubber boot above it. Any ideas where I'm getting water in, or why it's leaking lube out of that weep hole?
Both inlet/outlet water pipes looked ok, one was kinda crimped a little but I straightened it out. Also to note--prop seals looked fine when I had that apart. Also to note, when I first got the motor I changed the gear lube right away and it was black, no indication of water--and supposedly run 2 days prior. This led me to believe that the seals on the drain/fill screws were the issue.
Any helps is appreciated, thanks.
