Just bought a FourWinns satara 204 21' cuddy cabin with an early model mercruiser 470. Got what I think is a good deal. Seller didn't know if it ran or anything about it. I stole it from him(I hope) for $900 with a double axle trailer with disc brakes. This is my first boat and im tryin to learn as much as I can. I changed all the fluids and checked voltages before starting and it fired right up. However, the 3" heat exchanger is leaking bad out of the end cap closest to the transome. The boat ran for about 5min and started to over heat so I shut it off. Hope I didnt damage anything. I Went to take the end cap off and without useing a wrench the whole end came off including the part that is threaded for the cap to bolt to. It looks like this peice was sodered on or something. I was wondering if this can be resodered or if its junk? Even if i can temporarily fix it so I can find out if the boat needs more work then its worth.
Has closed system cooling and no belt driven alternator.
Any info will be greatly appreciated. Most of what I learned so far has been from this site.
motor#5656298
outdrive# 5696159
motor#5656298
outdrive# 5696159
