WAVENBYE2
- Apr 28, 2007
- 1,636
While I am outside murdering the ants on our boat, I thought I would go ahead and fix the bilge pump, I believe the bilge pump itself is still working so I tested the wires going to it, no power(Humm) so I went to the switch and no power there either? two brown wires plugged in back and one of them should be hot and the other for when I turn on the switch to close the circuit to the pump so now I am on my back trying to trace the wires, neither brown leads go to the fuse box under the gauges. so on my back tracing wires. any other ideas? Just keep tracing until I find all the connections with wire tester??
