recently having probs starting my engine , starts fine in the am, make run down the lake, fish areas restart is fine, seems that when the air temp rises late in the morning, and I sit with the engine shut down for awhile, it is very difficult to start, need to move throttle all the way forward and sit on choke, and crank away. Eventually it will start the first time then seems to run out of gas, ball is soft, reprim ball and then try to restart, finally it starts with a plume of smoke, let it idle a bit then im off, good hole shot, 5300 rpm 65 mph all the way down the lake idles smooth once started, then again same thing happens, with start mode. just bfore summer put in fuel water separator, now have probs. With mariners with carbs , need to have it trimmed down, have been told that from the first day i owned it, prob i have now is like it is in trimmed up position, what would have an affect on starting with engine idle in the heat, just found another thing a bit ago, had engine hood off, pumped ball have fuel leaking up at oil injection regulating valve
