  #1
Old August 3rd, 2009, 07:18 PM
de de is offline
Default 1969 25hp Evinrude - Lower Cover / Carb Removal
I'm rebuilding my Dad's 25hp Evinrude. I plan to use it on the boat I'm building. It probably hasn't been cranked in 10-15 years, but was running fine as far as I know. I'm ordering a shop manual after this post, but I thought I'd get a head start and at least start to tear it down. I got the flywheel removed. What a pop when it finally breaks free! But I'm missing something when it comes to removing the carb. There physically isn't room to get it to clear the two bolts and the lower part of the cowling.
Do I need to remove the front part of the carb (silencer cover area)?
How do you remove the bottom part of the cowling?
This is my first post on this forum, so I hope my link below works.
Thanks in advance,
Doug,
Raleigh, NC
  #2
Old August 3rd, 2009, 07:54 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: 1969 25hp Evinrude - Lower Cover / Carb Removal
pull the knob off the needle, remove the screws from the plate, disconnect choke lever, take out bottom needle valve. remove nuts and carb comes out.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
Old August 3rd, 2009, 09:41 PM
14ftgrumman 14ftgrumman is offline
Why and how far are you planning on tearing it down? Check compresssion, rebuild carb and new water pump impeller.
If it ain't broke, don't fix it.
  #4
Old August 3rd, 2009, 11:04 PM
tx1961whaler tx1961whaler is offline
That's a beautiful looking motor, but it doesn't need torn down any more than you have it, except for removing the carb. Change all of the ignition parts if they are original (plugs,points, condensers, coils), rebuild the carb, change the fuel lines to ethanol resistant ones, change the water pump impeller and gearcase lube (don't take out the phillips head screw...) and you're good to go.
  #5
Old August 4th, 2009, 12:10 AM
de de is offline
Thanks for the help. I got the carb off and it looks pretty good. Just took the float chamber off, cleaned everything, and made sure all the springs, valves operate smoothly. I wish I would have taken a close-up pic of the needle valve before I removed it, so I'd have a good starting point on where to replace it. Hopefully the shop manual I ordered tonight will give the details.
I then removed the power head. I've cleaned one side as you can see in the picture below. Is this normal buildup?
Also, here's a shot of the ignition parts. Does anyone know of a good online retailer that sells a complete tune-up parts package? What should I expect to pay for it?
I have zero experience doing this type of thing, so I might be going overboard like you said. Too late now I guess.
Thanks again,
Doug
  #6
Old August 4th, 2009, 02:45 AM
samo_ott's Avatar
samo_ott samo_ott is offline
Those coils are newer and will probably still work fine. I'd just clean and gap the points. (but I'm known to be lazy that way!)
The carbon on the pistons can be scraped off gently. As long as there are no scratches or grooves on the sides of the pistons or cylinders, just remove the carbon best you can and you're good to go.
I just picked up a 1970 25hp, but it has internal problems so I will have to split the case unfortunately. Great power/weight ratio on these engines... One of the best ever built!
__________________
Steve.
  #7
Old August 4th, 2009, 04:31 AM
parts available at iboats.
You can't re-use the head gasket.
  #8
Old August 4th, 2009, 05:55 AM
do not reuse any gaskets, just asking for trouble. parts >> http://www.iboats.com/Evinrude_Outbo...8670--dz.36857
needle valve you can reset, direction and other good stuff here> http://forums.iboats.com/showthread.php?t=299680
__________________
FLORIDA GATORS
TEBOW Country
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1969 20 hp merc lower unit removal mgoloms Mercury & Mariner Outboards 3 June 29th, 2009 11:55 PM
1969 Evinrude 25HP shift rod bushing removal help! oldfarmall Johnson & Evinrude Outboards 3 June 21st, 2009 02:09 PM
1969 Johnson 115 - lower unit removal questions russellcframe Johnson & Evinrude Outboards 3 May 11th, 2009 11:46 AM
1991 90hp lower leg cover removal problem QuadManiac Force & Chrysler Outboards 3 August 12th, 2007 12:09 AM
inline 6 lower bearing cover removal fmb64 Mercury & Mariner Outboards 2 July 11th, 2005 12:25 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
