99wellcraft
- Jul 11, 2009
- 5
I was having problem with me t/t on my 1999 Mercury 115 o/b costal elpto. I figured out it was the trim motor. I bought a new Arco motor and put it on. While taking the olkd one off I had to loosen the bleeder valve to raise the motor up in order to get to the t/t motor. While doing this fluid squirted out of the bleeder valve on the right bottom of the t/t motor. I got it raised up and everything changed over to the new one. I pushed the switch on the cowling and it moved the motor up a few inches and stopped. i then pushed the switch the other way and it went down a few inches. now it wont go up or down but the t/t motor still sounds like it is running fine. I made sure it was full of fluid and I have manually tried to raise the motor and let the air out of the reservoir but nothing seems to work. Could the little shaft (1 inch shaft) that goes from the motor to the hydraulics have broken. I am frustrated as heck. Please help!!!
