rfelectron
- Jul 11, 2009
- 5
I'm talking about the 2 holes on either side of the lower unit close to the front bolts that hold the lower and upper units together. Question: When the engine is running on water muffs should water be coming from these weep holes?
I am getting plenty of water through the engine, but I'm wondering if the coupler that connects the stainless water pump housing to the copper pipe might be leaking causing the water to come out the weep holes? I don't understand where the water coming out the weep holes is coming from and if it's normal or not. Thanks in advance, Lee
