  #1
Old August 3rd, 2009, 09:07 AM
sidescan sidescan is offline
Default 1987 Mariner 9.9 shift linkage disconnect
I recently purchased this motor and a Seloc repair manual. I cannot disconnect the shift linkage to remove the lower unit in order to change the water pump impeller. I removed the three lower unit bolts and the lower unit drops about an inch but no more. I cannot see a bolt, clip or any other means to disconnect the linkage. Does anyone have information specific to this motor?
  #2
Old August 3rd, 2009, 12:10 PM
green4themoney green4themoney is offline
Default Re: 1987 Mariner 9.9 shift linkage disconnect
the shift disconnect is on the exterior of the motor, look in front of the driveshaft housing and you will see a skinny silver rod (shift rod) and it has a clamp on it, you need to remove this clamp
  #3
Old August 3rd, 2009, 12:47 PM
Thanks for your prompt reply. The only clamp I see flips a lever type device. When I unscrewed it the only thing that happened is it slides loosely up and down the shaft but does not disconnect the shaft. Any other ideas?
  #4
Old August 3rd, 2009, 01:02 PM
here you go
  #5
Old August 3rd, 2009, 01:05 PM
sorry the picture is small but if you look closely you can see the silver shaft and i circled the connecting clamp
  #6
Old August 3rd, 2009, 01:20 PM
  #7
Old August 11th, 2009, 03:38 PM
The mystery is solved. The motor in the picture is not the 1987 in question. Seloc's manual has struck out twice. They said the spark plug gap was .24 inches but the manual says .43.
The disconnect, courtesy of Sunset Marina's mechanic on Ten Mile creek in Millsboro PA, is located under the cowl where the shaft connects to the lever mechanism. You flip up a tang and pull it out which pulls the tang's shaft from a hole at the top of the linkage rod.
Thanks for the attempts though.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
GT150 shift linkage disconnect cbeam2 Johnson & Evinrude Outboards 15 November 13th, 2007 10:28 AM
Shift linkage disconnect olecarman Mercury & Mariner Outboards 4 January 11th, 2005 01:37 PM
Shift linkage disconnect 86 225 Johnson v12mac Johnson & Evinrude Outboards 10 October 24th, 2004 01:37 PM
Disconnect upper shift rod linkage 1980 35hp Evinrude? Kickin Bass Johnson & Evinrude Outboards 2 October 15th, 2003 08:32 PM
..and exactly where to disconnect the shift linkage willtill Johnson & Evinrude Outboards 7 December 11th, 2002 03:32 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
