4.3 mercruiser got fuel and spark no fire
remi_357
1986 mercrusier 4.3. New ignition module, pick-up sensor, cap, rotor, plugs, wires. It cranks over and has a nice spark, just wont fire. All I get it back fires out of the carb and exhaust. Started with timing a 0 degress and moved it clockwise and counter clock wise and no change. any ideas? also i tripled checked the firing order and it is correct
Re: 4.3 mercruiser got fuel and spark no fire
Ayuh,... Sounds like the distributer is 180? Out...
Fix'em
I agree. If you have spark and fuel, then you cap is on 180deg. out. Check it out and let us know.
